The outlets on my back deck stopped working. I traced it back to a GFCI switch in the bedroom about 6' away. It wasn't tripped so I figured a bad plug. I started by replacing the GCFI but that didn't solve the problem.
Pushing the restet button trips the power to the room (circuit)
I've searched the house for upstream GCFIs and found none that are not working.
A three prong tester light confirms the GFCI is not working. My multimeter shows no voltage but I got zapped so something is there. I also used a KLEIN Tools tester: The red LED indicator lights up but not like a properly functioning outlet. The LED light flashes slow then fast and then turns green indicating no power. Basically, I get irregular results and the tools manual does't indicate what the results mean.
Any ideas? I'm leaving it alone until I get some help - no more zaps
