Breaker Tripping
  • 911Restoration
    • Nov 2006
    Breaker Tripping
    The breaker keeps tripping but only when I run the microwave AND the toaster at the same time, like clockwork every time. Is my house wiring dying? It's an older house... Any tips or suggestions would be much appreciated!
  • jackofall
    • Mar 2004
    • 53
    Nothing's dying, you're just overloading one circuit. Older houses especially kitchens often only have one 15-20A circuit for counter outlets, and microwave + toaster together is easily 15-20A on its own before anything else is running.
    Breaker tripping is it doing its job, not a warning sign of failure. Fix is either don't run them together, or have an electrician add a dedicated circuit for one of them (cheap compared to a full rewire). Do NOT just put in a bigger breaker to stop the tripping — that's how you get a fire, the breaker size has to match the wire gauge. If you don't know the wire gauge, don't touch it, call someone.
    Otherwise could you move the toaster to a different wall or counter? Perhaps another area of the kitchen (or perhaps in a pantry, etc.) are on a separate breaker?
    • dntreecareinc
      • Oct 2026
      • 15
      That pattern points to load, not failing wiring. A microwave is usually around 1,200 watts and a toaster around 900 to 1,500 watts, so together they can pass what a 15-amp kitchen circuit can carry, and the breaker trips doing its job. A quick check is to run the toaster from an outlet on a different circuit, such as in the dining area, while the microwave runs — if both run fine apart, the circuit was simply overloaded. If the breaker trips with only one of them running, or it feels hot, buzzes, or smells scorched, leave it off and have an electrician look at it rather than swapping in a larger breaker.
