Aluminum Wires
  • taxibabe
    • Nov 2003
    Aluminum Wires
    Hi,..I want to replace a light switch. The hardware store has switchs with aluminum wires; and others without. How do I tell if I have aluminum wires..Thanks, Carol
  • handyandy
    • Sep 2002
    • 210
    When was your house built? Generally houses that were built or had wiring done between 1965 to 1978 are suspect for aluminum. What color is the wires that you would connect your new switch to?
    • taxibabe
      • Nov 2003
      Hi..This house was built in the 60's(I've been here for 26 yrs)There's three black wires, and one white one. I guess It's aliminum..Is that bad??..Thanks..Carol
      • dennisw
        • Feb 2004
        Copper wires are "copper" colored. Aluminum wires are a "silver" color. Both types can be coated in either a black or white plastic.
        • irregularjoe
          • Nov 2003
          • 176
          if you are not sure, buy a switch thatis rated for both AL and CU. (aluminum and copper)
