Hello new to these forums, hope you can help.
I have a GFCI plug where the reset button doesn't work. I pulled it out and replaced it with another GFCI plug thinking maybe the outlet was bad. The new one does the same thing. I noticed that this plug was in a serial so I went around and found that another plug in my garage doesn't work and there was a plug outside the house that doesn't work. The plug outside was in the elements, the door that protected it was open and I'm pretty sure water or something got in. So I tried another theory of just disconnection the rest of the plugs by unhooking the "load" part of the outlet on the GFCI plug. However the GFCI plug is still having the same issue, so I'm kind of torn on what to do now. Any suggestions?
