Hi,
I've just purchased a new hot tub. Although my house was pre-wired for a hot tub, I've found out they only wired with #8 wire and a 30A breaker. My tub needs 50A to work well.
My current idea is to just remove the existing 30A breaker from my service panel. I'll cap off the existing wires and just leave them in the wall. That will allow me to use that space for a new 50A (or 60A) braker. I then plan to run new wire ~13' along my garage wall and into my crawlspace. Then it will run ~40ft to the rear of my house. It'll then exit the house and go up 6' to a "spa box" with a GFCI and a disconnect.
Here's my questions:
1 - Should I go ahead and get #4 wire instead of #6? My tub will work with 50A but will allow all jets and heater on only with 60A. Maybe #4 isn't a bad idea?
2 - I realize I'll need conduit along my garage wall. I've been told that it is against code to install romex within conduit and that if I want to use conduit then I need to use individual cables instead. Is this true? If so, what gauge bare wire do I need? Must it be #4 as well? The 6/3 romex seemed to have pretty small bare wire compared to the other 3 main wires.
3 - In my crawlspace, do I need to use conduit? I'm currently thinking I'll go ahead and use 1" PVC conduit or 1" flex-metal conduit in there just to be safe.
4 - Once the elec gets outside from the crawlspace I plan to use the water-tight flex metal conduit. I'll put in a box where it first exits the house and then run the conduit up the wall a couple feet to the spa box. Then, I'll use the same water-tight flex-metal conduit for the 9' run over to the hot tub.
Do these things sound right? Any suggestion or other recommendations? If it matters, I'm in King County in WA state.
Thanks in advance!
Thanks in advance!
