Installing ceiling light
  • snoweymonkey
    • Mar 2004
    I've been using lamps for lighting in my bedroom and I would like to install ceiling for better lighting. There is a single pole switch next to the doorway. How can I use that switch to control the celing light?
  • LightnBolt
    • Mar 2004
    • 6
    Are the lamps turned on by the wall switch?
    Zips_LightnBolt
    • snoweymonkey
      • Mar 2004
      Yes
      • irregularjoe
        • Nov 2003
        • 176
        Tap into the switched plug and run a line up to the new light.
        How you do this depends on where the wiring is located....Attic?
        If so, can you get up there?
