Installing ceiling light
  • Installing ceiling light
    I've been using lamps for lighting in my bedroom and I would like to install ceiling for better lighting. There is a single pole switch next to the doorway. How can I use that switch to control the celing light?
    Are the lamps turned on by the wall switch?
    Zips_LightnBolt
      Yes
        Tap into the switched plug and run a line up to the new light.
        How you do this depends on where the wiring is located....Attic?
        If so, can you get up there?
        Did you ever see OHM'S mother in LAW?...... SHOCKING!
