panel & furnace
if you look below the white neutral bar you'll see where the bare grounds connect to.
I looked at home depot and they list a Murray breaker with a 20-40 and 40-20 configuration. stock no begins with MHT.
getting one may be a different story.
in the future you may consider changing out your whole panelbox to a larger, more space board. if you're not ready for a 200 amp 40 circuit panel, they make a 100 amp, 30 space panel.
what you have is a 100 amp 20 circuit spaces filled with tandem or twin breakers.
