I have an older 8 ft. 3 tube(single pin) fluorescent light fixture with 2 ballasts, one ballast operates the two outside bulbs and one operates the middle bulb but only the middle bulb is working. Each ballast has a red and blue wire coming out from one side of the ballast close together and the other side has a black and white wire coming out close together. What I need is a wiring diagram showing how this light should be wired, if anybody knows how it should be wired could you please post a diagram for me....Thank You.
8 ft. fluorescent fixture
flourescent sockets
sockets are either bi-pin or single pin. high output sockets have a plastic horizontal locator between the tube pins
the wires push in or use a screw terminal that can accomodate two wires under each screw head.
a number 18 gauge solid insulated wire is usually used. printed or heat embossed into or on the plastic jacket is the voltage rating - 600 volts or less.Comment
