Wiring 3 new bucket lights in kitchen
  • mr.B
    • Nov 2013
    • 5
    Hi,
    Hopefully my goal here is achievable fairly easy with my existing wiring.. I am new to home improvements and am looking to remove my current lighting and install 3 of the bucket led type lights that recess in the drywall.. Currently I have a 5" or so hole and an 8' fluroscent fixture (all encased by a hideous 1970's "box" in the ceiling). I don't even know how to explain what I have, it is just very ugly. So I am tearing out this whole "box" and the fluorescent light an I would like to install these bucket lights.
    Does this sound doable? I seems to be the only light on the circuit so I was hoping to be able to just run wire to each box and thats it? Hoping to also install a dimmer switch in the wall as well.
    • 8747
    new lights
    you are going to have to find a retro fit can light that will utilize your existing "hole."
    I'll do some searching and see what I can come up with. I had a guy in another forum that had a similar problem.
    First make sure you know which circuit feeds those existing lights. Mark it at the panel.
    Is there an existing wall switch?
    • mr.B
      • Nov 2013
      • 5
      Well, I only have the one hole, so I figured I would just patch that hole and then make new holes were I want the cans... I am in the process of texturing all the ceilings right now so I figure I would like to get all this stuff figured out before hand. (I am just moving into a new place).
      Yes there is an existing wall switch, it has two switches on for the kitchen light and one for the garage.
      I tried to post a link but I cannot yet... Sylvania 70734 is what I was looking at. Is this about what I need?
        • 8747
        retrofit cans
        The lamp kit you have quoted is just for the LED. You need an old work light fixture.
        I have two attached items. One is the recessed can, the other is the LED insert for the can.
        check on specs for a dimmer BEFORE you install the LED assembly.
        Some are compatible many are not.Click image for larger version
ID:	87240Click image for larger version
        • mr.B
          • Nov 2013
          • 5
          It seems these LEDs are newer on the market. Would you recommend them over an incandescent type?
          One thing I am unsure on is can I run the existing wiring to the closest junction box, and then "piggyback" the wire to the other two? Or do I need to run seperate wiring to each light box.
          Thanks, trying to learn basics.
            • 8747
            can lights
            once you locate and bore the holes for the cans, daisy chain the wiring from one fixture to another. the last one in your run [or the first one] will go to the switch. connect all [line in to line out and fixture wire], line in to line out and fixture wire, and so forth.
            answer to your question.
            incandescent has been around for ages. installing a dimmer for incandescents is easier because of less variables. dimmers chop the ac into pulsating dc to operate a triac within to afford the dimming.
            LEDs require an internal transformer to reduce the current to a usable level to operate the LEDs. Dimmers don't like transformers.
            That is why I suggest you inquire of different manufacturers in case you want to retrofit your cans for LED lamps.
            • mr.B
              • Nov 2013
              • 5
              Last dumb question, line in to line out. fixture wire. What exactly does this mean.
              I found a nice kit at home depot. They are about 50$ for the fixture w/trim ring and LED. Sounds like a pretty reasonable price. is 14 gauge sufficient for the 3 lights?
                • 8747
                can lights
                14 gauge is sufficient for the lighting. a lot of houses being wired use #12 romex throughout even for lighting. I find it more difficult to shove #12 into a box than #14.
                just make sure the circuit feeding the lights has a 15 amp breaker connected to it. if yours is 20 amps and the kitchen lights is all that's on it, change it to a 15.
                you don't want to intermix 12 & 14 on a circuit.
                • mr.B
                  • Nov 2013
                  • 5
                  Ok I will check the breaker. I flipped it the other day but didn't notice the amperage on it. Now I feel plenty confident doing this ! Of course where I want to put the lights is near the roof so it is a bit of a crawl through the attic and laydown to get there Everywhere else has heaps of room !!
                  thanks a lot
