test knob and tube wiring
  • deejal
    • May 2004
    • 9
    Is there a device that can test to see if the knob and tube wiring is still live?
    I have a circuit breaker box with modern wiring, however, I still see knob and tube wiring all over the basement. I try to trace it back and it just disappears into somewhere. Can knob and tube wiring be connected to romex then connected to the main circuit panel breaker box? I see lots of splices. There are no fuses anywhere.
  • volts
    • Mar 2004
    • 68
    Can't you determine whether the knob and slob wiring is tied into the panel? Find a convenient point along the old wiring where you can attach a VOLTMETER and simply measure for voltage. With a CLIP-ON AMP-PROBE you can read its current without baring the wire. Assumedly, this old wiring was abandoned long ago, but always verify.
    • kactuskid
      • Mar 2004
      • 801
      Your knob and tube wiring should never be extended by splicing romex to it. It is against code to extend a non-grounded circuit and also dangerous. You could test the old wiring using a non-contact tester such as this http://www.amazon.com/exec/obidos/tg...83900?v=glance though they can give false readings at times. Try to go into the attic to see if the knob and tube exist up there and if it is energized.
