Hello,
I'm doing a complete rewiring of my house, and I'm wondering about plastic vs metal junction boxes. I have put in a large (6" cube) PVC box at the end of a 1 1/4" (PVC) conduit run from the panel. At the other end I will run NM cable to the circuits. The box came with no pre-drilled holes to run cable. When I drill a hole, I cannot fit a standard 3/8 cable clamp into it - the PVC is too thick and the clamp threads are not long enough. I cannot find another type of clamp that seems like it would work. Is it ok to run the NM out without clamps, as long as it is stapled very close to the box? The code I read says all wiring methods must be "secured to the box". How are you supposed to do this with this type of box?
Thanks for any help.
LRoadie
LRoadie
