What does the eye bolt have to attach to for a 200 amp service. Can you just screw it into the wall studs? I've been told you have to tie it into the ceiling beams. Is this correct?
installing eye bolt
Tags: None
The so-called "house-hook" is an eyebolt about 14 inches long with 5/8-16 thread, two washers and two nuts. It goes from the outside finish wall through the stud space and through a horizontal framing member. There is is brought up tight with nuts. The horizontal service conductors are attached to the house via the ground messenger cable with a wedge type anchor that tightens as more tension is applied. The service entrance conductors go through a service entrance weatherhead and are tied to the service lateral applied by the power company.
