The house we bought has a family room that controls two ceiling fans with a dimmer switch. Is this normal? It doesn't appear the setup works too well and although the speed seems to change a bit (but hums on anything other than fully on or off) you certainly can't control the speed of the fan from Low, Medium, High like you could with the chain. I can see what they were thinking b/c the fans are on a high cathedral ceiling and are impossible to get to the chain without a ladder.
Also, our bedroom has a single dimmer switch that connects to a light/fan combo. The dimmer switch turns the fan either on or off but can dim the light. But when the light is dimmed and the fan is on, the fan hums like crazy unless the light is fully on or off. I know I can rewire the setup to avoid this but I wonder, should fans be controlled with a dimmer?
