A couple of weeks ago my front porch GFCI went dead which caused all my bathroom outlets (3) to be non functional. I had a test button with a light on this outlet and I was unable to test it, it had no reaction except for the light would flash for a split second, then go off, the buttons would not push in. I have no other outlets or lights that have gone out, seems to be limited to these 4 outlets. I assumed the outlet was bad, bought & i nstalled a new GFCI. Well, didn't help. My electrical work is very limited so I went to the local Home Depot and bought a receptacle tester and an outlet tester (the one with the 3 lights). When I plugged in the outlet tester, I received a "neutral contact not connected" or "open neutral" reaction.
So, today I turned the power off to that outlet at the breaker box, took the new GFCI off, capped the wires and then turned the power back on. I tested the hot wire with my tester and no reaction, no power to the GFCI.
Where now? Is my breaker possibly bad?
