I turned off my circuit breaker for the water pump and turned it back on and now my water pump will not start
water pump problems
We are having a problem with our well water. This has only started in the past month and is becoming more frequent. Sometimes when you turn on the taps there is no water. When you shut the tap off and wait a few minutes there is water. It's almost like there is an air lock. Any suggestions.
There are some pressure tank switches that will "trip" and disengage whenever a demand is put on the pump and the power is knocked out (storm?)
One type of 'trip lever' switch is a Square D type sfg 2 ,9013
Without this type of 'trip lever' switch, when the power is interrupted when the pump is running (water demand) the contact points will have to be manually re-set.
This was the scenario for Lucasm's previously posted question.
The points had to be manually re-set because 'Lucasm's' switch was not equipt with a trip lever.
Re-setting by holding the contact points (220 Volts?) down can be a very dangerous task, especially for some (not all) diyers.
To Rob Moss;
Shut off pump power. Drain the tank, check air pressure in tank. It should be 2 psi below the pump's cut-in setting.
Another cause could be some 'debris/crud' has accumulated around the 1/4" or 3/8" nipple/tube that enters into the switch.
Remove the switch, clean or replace this nipple or tube .
Turn power back on, re-fill tank.
check for operation/leaks, etc.
Good luck....Hube
