I need to run a 220vac (hot-neutral-hot) and 4 or 6 110vac lines from the main breaker box to a bedroom that I am remodeling. I bought a sub-panel box & connected it to a main breaker on the main breaker box, and was planning to run a handful of 14-2 Romex cables back to the bedroom.
Instead of a bunch of small wires, can I run a big wire from the main breaker back to a sub-panel box in the back bedroom, and use short runs from the subpanel to the bit&pieces?
If this works with code, it would decrease my wiring cost, & decrease the power lost in the wiring during non-peak use times, but I don't know if this is ok with code & such.
Thoughts??
Thanks!!
Thoughts??
Thanks!!
