Problem began as no power to 2 bedrooms. Ceiling fan/light in bedroom1 works, also bathroom on same circuit works. Replaced every outlet & switch that don't work in both bedrooms. Then used a little 'testor'-(2 probes & a light bulb) to check for power. On each of the outlets we now get a light when inserting the probes into the sockets, but nothing we plug in will work.
We just learned that one of the outlets in bedroom 1 has been working off & on for some time.
We just installed shelves, which required drilling & mollys, on the wall of bedroom2 (common wall). Don't think that is significant, but thought maybe something was jarred loose. Nothing appeared loose when replacing the outlets, though.
We don't know how to determine the order of outlets on the line, and not quite sure if we need to. (Saw that referred to on another post).
Any suggestions?
Any suggestions?
