This summer, I plan on running power out to my detached garage.
Conditions: All season weather upper midwest USA. Distance run is about 60 feet. 120 VAC, have not sized current rating yet, lets say 75 Amp as an estimate.
Underground seems more appealing to the eye then overhead and easier to install. From a safety stand point, is underground the way to go also? Or maybe a better question is, what limitations and or liabilities does underground have-if any?
Also, I intend on pouring a sidewalk between the house and the garage. Would i run the conduit next to the sidewalk or under it?
How deep in the ground should the conduit be? For example does it need to be below some type of frost-line?
Thank you.
Thank you.
