Baseboard heater installation
  • rajrac
    • Apr 2006
    I'm very new at this and like to know if I can install a baseboard on the inside wall instead of outside wall. i can access my inside wall from the other side. The heater is 1000watts 240v and using 12/2 wire.
    1000 watts divided by 240 gives you 4.167 amps. you'd be safe to use 14/2 on a 15 amp breaker. If your upper and lower walls align with each other, maybe you can snake a wire in between the walls.
    • Hube
      • Nov 2003
      • 453
      Rajrac;your question was..." can i install on inside wall...' and the answer is YES, no problem.
      And use the 12/2 wire and you will be better off.
      • rajrac
        • Apr 2006
        baseboard heater
        Thank You guys for a quick reply. i will try it on the weekend.
