Light - Light - Switch Wiring Question
If supply power is coming into one of the lights first, then yes, you need to install 12/3 between the lights in order to be controlled by one switch. The switch is being wired in a switch loop fashion so the white wire is actually a hot wire and not a neutral wire. You'll need to mark it as so by coloring it at both ends using a black magic marker.
Here's another link that'll show you how to install this type of circuit.
Is there a switch box already in use that has wires going into it? If there is then you'd only be adding a 12/2-g cable to wire it switch=light=light.
By wiring the switch as a switch loop instead just be aware that you will never be able to tap power from this switch as there will be no neutral wire available.
Originally posted by kactuskid View PostIs there a switch box already in use that has wires going into it? If there is then you'd only be adding a 12/2-g cable to wire it switch=light=light.
Thank you for all of your help.
