Hi
I would appreciate some suggestions for adding electrical services for a new detached garage. In addition, I have another future addition that might also play into this addition.
I’ve done a little reading on the subject, but have never done anything like this before other than installing ceiling fans and minor items of this nature. I’m probably capable of running wires to receptacles, switches, following code guidelines, but would not attempt any final connections, etc. that would have safety implications. I expect to find a licensed electrician to perform those or other tasks that are appropriate.
So what follows are a few alternatives (may or may not make sense – would not limit thinking to these!) that I conjured up after reading a little and some details on my existing house service panel and anticipated loads for the new detached garage/possible future addition.
Detached Garage & Future Electrical Needs
Existing House
New Detached Garage Addition
New Carport Addition/Existing Garage Close-in (future)
- Double lugs at the existing house meter outlet: one set of feeders to my existing house service panel and another to a new service panel in the new detached garage. I understand that I would need to check to see if this is permissible or not with parish or power company regulations.
- Other means of splitting main service feeders to accomplish the above?
- Adding a sub-panel in my existing house off the main service panel and then supplying power to another sub-panel in the new detached garage (I don’t know if this is allowed or not; it would have an advantage to provide some spare circuit capability in the existing house. Likely would require upgrading the main breaker also? See details below).
- Adding a sub-panel in the new detached garage off the existing house main service panel. One concern here is available breaker locations in the existing service panel.
Existing House
- ~3000 sqft
- Square D Q0 Main 200 amp Panel w/150amp main breaker
- 30 slots/with 10 twin capable slots
- All slots occupied, but there are 4 of the twin slots with just a single breaker
- Estimated existing load: Normal 110a (240V); Maximum 140a (240V)
- Electrical is underground (required by subdivision)
- 60’ from existing House Main Panel
- Estimated load: Normal 10a (240V); Maximum 26a (240V)
- Circuits: 5 identified, probably a couple spares
- Presumably would want to run 240V to Garage (smaller cable?)
- Adjacent to House Main Panel, in-between house and detached garage
- Existing garage circuits probably adequate for closing in garage
- Estimated Incremental Carport load: Normal 2a (240V); Maximum 10a (240V)
- Carport Circuits: 2 identified (probably want to supply these from House Panel if possible). A couple spares would be nice, but not required.
