Thanks again for your replies!
I would certainly be very careful when opening both outlets and the breaker.
I've opened a few outlets before, so I should be able to check for loose connections.
I'm a bit doubtful to the broken outlet, only because the power was lost when a hairdryer was used simultaneously as a few other electrical devices using the same outlet. Sounds to me that it would be the time when a breaker would trip, but you are the experts.
I would certainly shut off the main power when going in to any of these outlets...if no luck, I'll call the experts.
Thanks again!
Thanks again!
