Electrical Outlet only works 2ith 3 prong plug
  • Brad
    • Dec 2003
    I have an elecrical outlet in the home that only works when I plug a three prong cord into it. When I plug in a two prong device (no ground prong) like a blow dryer or iron, it doesn't work. I have replaced the outlet and I also made sure the bare ground wire was attached to green ground screw. Help.
  • Jimmer
    • Oct 2003
    • 274
    Brad,
    I would guess that there is a break in the neutral wire somewhere between the electrical panel and this outlet. If you have checked the wire connections at this plug and this is the last outlet in a series then it would be at the outlet before it (assuming that outlet work properly).
    Good luck, Jim
    • Brad
      • Dec 2003
      Thank you very much Jim. I will check into that.
      -Brad
