[B)] I originally had an electric range installed in my house. I converted to gas 10 years ago. I just replaced that range with a dual fuel wich uses 220V for the oven. I figured no problem installing the new one just plug the new range in the old outlet. Wrong answer!
The old range was hard wired. So, I go out an buy a 3 prong outlet (3 wires in the box 1 black insulated, 1 black/red insulated, and 1 bare wire} However the package says this outlet is a non grounded outlet. That bare wire is a ground. Correct?
Problem #2 the range has a 4 prong cable which I went out a bought a 3 prong replacement which the manual said to do. How do I wire the outlet to correctly operate the range?
Any and all help would be GREATLY appreciated!
The old range was hard wired. So, I go out an buy a 3 prong outlet (3 wires in the box 1 black insulated, 1 black/red insulated, and 1 bare wire} However the package says this outlet is a non grounded outlet. That bare wire is a ground. Correct?Problem #2 the range has a 4 prong cable which I went out a bought a 3 prong replacement which the manual said to do. How do I wire the outlet to correctly operate the range?
y
