What’s the reason behind burn out of CFL?
  • mossrisjhons
    • May 2009
    • 9
    Whats the reason behind burn out of CFL?
    I used it for just 4 months and it burned out.
    Why so? due to high voltage or something?? or any other reason.
    they're small and they create heat which causes them to self distruct.
    • mariyasmth11
      • May 2009
      • 9
      Well, I think that might have happened due to high voltage.
      Sometimes, in some cases that just happens due to high voltages and can be same in your case i think.
        mariya - have you had any electrical theory? you should know that flourescent lamps of ANY type use a higher than normal voltage to "flash over!"
