GFCI outlet question
  • charmed
    • Feb 2010
    • 36
    I have a bathroom with a GFCI outlet (well, will be, once I can figure out how to hook it up), a fan and a light.
    The outlet box has two cables, each with a black, white, and ground. When I got to it, the electrician had wired the two blacks together, and the two whites together. In this configuration, both the fan and light work.
    I tried taking those apart, so all wires were apart, and then the fan and light didn't work.
    I determined which black wire was hot, and on the GFCI outlet, I hooked the hot black to the "line" with gold screw. The white from the same cable I hooked to the other side with the silver screw. To the load screws I hooked the other wire (again, black to gold and white to silver). I tried it, and the outlet, fan and light didn't work.
    I tried tying the blacks and whites back together like they were before and put in pigtails. In this configuration the light and fan went on. So I hooked up the pigtails to the line screws, and then the fan and light still went on but not the outlet.
    What gives? What am I doing wrong?
    Dawn
    did you press the reset button on the gfci?
    • charmed
      • Feb 2010
      • 36
      Ugh
      No, I didn't try that. How dumb of me. I will have to try it on Saturday when I'm at the property next. If that is the solution I will feel really silly.
      Dawn
      • charmed
        • Feb 2010
        • 36
        Gah
        That was it. Now I feel dumb.
        Dawn
