GFCI outlets
  • ralr2000
    • Feb 2004
    GFCI outlets
    My GFCI outlets in my two bathrooms don't work. I cheked the breaker circuit box and its working properly, in my garage I have another gfci outlet and it wokrs fine.The weird thing is that I used an electric tester and I found that is not power in my bathrooms outlets, but the light switches both work just fine. Please any idea about what is happening.
    rl.
  • Jimmer
    • Oct 2003
    • 274
    Rene,
    Welcome to the forum.
    You need to find the GFCI that has tripped, it could be in the garage, kitchen, another bath or even outside. Once you reset it then the circuit will work.
    It is alright that the lights are not on the same circuit.
    Good luck, Jim
    • tricia
      • Feb 2004
      • 20
      Same thing happened to me try to reset gfci in your garage usually that is where they are located mine controls all 3 bathrooms usually when i use blow dryer or portable heater. I just go to the garage push button at outlet it will trip back on , if not the correct outlet try the others around the house. You have nothing to loose
      • irregularjoe
        • Nov 2003
        • 176
        Bath light are usually on a seperate circuit, that shouldn't have anything to do with it.
        Take the gfi's out of the workbox and check the wiring. Are you getting power to them?
