Electrical outlet #1 is a GFCI duplex outlet.  there are 3 additional downstream outlets on the circuit.
When I test the GFCI outlet, using the test button on the outlet, the downstream outlets lose power but the GFCI outlet stays powered.
The outlets are 28 years old.
What is the most likely cause and solution to the GFCI not functioning correctly when tested? I'm thinking that the GFCI has failed internally.
