cheaper ? concrete floor or wood floor??
  • pi71
    • Aug 2004
    • 10
    Im going to build a cabin on my land. It will be roughly 30'x30'. what do you think would be cheaper , a concrete foundation or wood floor foundation?
    Measure 2wice cut once.
  • Hube
    • Nov 2003
    • 453
    Concrete. Wood when it gets wet will rot.Concrete will not. The problem is concrete is cold on the feet, so put some wood flooring over the concrete and you will be all set. The CHEAP way out is never durable in the long run. Do it once, do it RIGHT....Good luck, Hube
      Just an idea but think about this. Where you excavate the ground for the base, put down a smooth, level layer of sand. On top put a layer of 6 mil poly. On top of this put 2" urethane panels with the joints taped with duct tape. Pour your concrete on top of this, within forms all around the slab. Screed it off level with the boards and finish it off with a whirly-bird trowel (powered trowel) let it cure slowly - keep it moist. With the urethane you'll have an isolated slab above ground with insulation board underneath so it won't be so cold.
