Hi,
I'm going to put down a pine floor in my entry room. I've pulled the carpet and all the old layers that were under that (partical board, linoleum, plywood, two more layers of linoleum, and a layer of newspaper from 1915(!)).
I'd like to put a layer of backerboard such as HardiBacker to bring the floor level back up close to where the carpet was. Should there be a layer of something else between the sub-floor and the backerboard? I've heard of people using tar paper, resin (rosin?) paper, or roofing felt. What do people recommend? Also, should there be a similar layer of some sort of paper material between the pine boards and the backerboard?
Lastly, the pine boards I'm using are salvaged high-school gymnasium bleacher boards. They're 3/4" thick, 7 1/2" wide, and between 14' and 18' long. They are not t&g. I suppose i could route a notch in the sides so that they overlap a 1/2" or so if it was really important. Otherwise I'll just leave the edges of boards straight. I'm thinking that I'll just use screws to fasten the boards to the sub-floor, going from one side of the rom to the other, laying each board and fastening them one at a time. Any general advise or warnings here?
Thanks for any help.
