I just bought a 1950's house. The Kitchen has roll linoleum. I saw a TV show where they painted the linoleum - does this really work? Will it hold up to traffic?
Yes
I am familiar with the process that you are referring too. A friend of mine had his bathroom floors sprayed and I hired the same guy to spray my kitchen counter tops. I will try to find out what type of paint he used, but I believe his preparation process was a key part in the lasting finish. I had my counters painted 2 years ago & I still love the way they look!
For my kitchen counters, they treated the surface with a chemical that "ate-off" the glossy finish. The chemical removed all of the color from my counters; the result was that the counters were a brite-white and felt porous, almost brittle. Then they sprayed the "granitizing" paint over the counter tops, and then lastly covered the new paint with a clear-coat substance. This is the same process they used on my friend’s flooring too.
I wonder how durable the finish would be if you were to paint your vinyl without some type of chemical pre-treatment. The acid preparation process that removed the gloss & color, made a perfect surface for the paint to adhere too. I am far from an expert, I would suggest talking to some professionals about your flooring. The process was not expensive, and it was great to have them tape off everything and clean-up. The guys I hired advertised as bathroom refinishers. But they told me that they have been hired to paint tons of stuff; from vinyl, counter-tops, furniture, people even hire them to paint rooms (and I am sure that would hide anything!).
Good luck & let us know how your project turns out!
cabarber, It would be nice to know what you decided. I would think that replacing the flor would be a better choice. Then again, nobody is going to convince me that I don't want to spend the time sanding my MB floor. I like the beat-up look of it & the fact that it's tongue & groove.
Hi.... Painting a lasting design on the floor is possible! The trick is varnish, varnish and varnish! You apply the basecoat then stencil your design on top (if desired) for example, a cobblestone or flagstone look. Perhaps a nice oriental rug? Then apply at least 4 coats of acrylic varnish. If it is a high traffic area I would suggest more. After each coat is dry, sand it very lightly, this helps give depth to the floor. Hope this helps!
What's the actual right way to clean hardwood floors? I don't think I am getting them clean and am worried that if I use anything strong I will ruin them....
