floor noise?
  • smr
    replied
    Hi,
    Why didn't I think I actually can purchase some specific nails and do it by myself? Thanks for the info.
    Another question: how think is for the subfloor normally?
    replied
    I'd tend to agree with you. There are special screws to use for this purpose. They appear as two heads on the same shank with a narrow neck between them. When the first head bottoms out beneath the carpet, then the neck snaps, leaving no protrusions. Finding the floor joists can be done with a regular stud finder, I'd expect. All of that can be found at a box store....
  • smr
    started a topic floor noise?
    floor noise?
    Some area on the third floor will have noise when I stepped on it. The reason for this I think is because the subfloor is not nailed into the Joists strongly. Since 90% of townhouse/single house use wood as major material. I assume this is normal. Did I guess this right?
    Waiting online for your input.
