My plumber put notches in a about 10 joists for a 2 inche pipe and put them in the middle of the joists.  Also at the end of the joists, there are 2.5 inch holes and a gas line going through.  Beside the gas line holes are notches again for another pipe that is 2 inches.  How much will this weaken my floor. Is it dangerous because the gas line is going through?  I would appreciate any thoughts.  I know code says that the notches should not be in the middle third span.  Are the gas notches to big.  By the way my joists are 2 X 8 and span about 12 feet. I want to make sure the floor is safe before drywalling the ceiling.
Thanks for any help.
