Is it possible to repair about a foot long and half foot wide bleach discoloration of the living room carpet without replacing the whole room's carpet. If so what would be the approximate cost?
Carpet repair
Tags: None
This problem can usually be handled very easily by a good carpet installer. They cut out the bad piece and invisibly seam in a new piece to replace it.
The problem is finding a suitable replacement piece to make the repair.
If your carpet is fairly new and that type & color is still in production they may be able to get a new piece to make the repair. If not, you may have some extra carpet in a closet that could be removed and used for the repair.
One of the major problems you may encounter is if your carpet is a bit older or exposed to direct sunlight the color may be faded slightly, which would make it nearly impossible to get an exact match.
There are a number of other tricks that carpet installers use, such as -redying the carpet, or in some instances when the damage is adjacent to an entry door they can cut it back and install a vinyl or hardwood sweep landing area near the door.
The best advice I could offer would be to contact a carpet store and have then send a carpet installer to assess your problem and give you the options.
