what type/brand of thin set do you use for to tile a shower floor??It will be used on concrete. the ready mixed stuff specifically states do not use in saunas, shower stalls, blah, blah.
tile on shower stall floor
You need to get the glue that is in powder form and needs to be mixed with additive or water. There are many brands Laticrete is one of them and both your big box stores carry them. You need to get a mid range ( I always go top end) product about $20/bag.
The cheapy stuff that is around $10/bag is just that, "cheap", the more expensive you go the better the additives they add to the mix.
