Hi,
About 5 years ago I had a water leak near my front door. The roof was replaced back then and the leak was fixed. I thought nothing more of it. However I am now replacing my peel and stick tiles by that front door and I have discovered a lot of bad (rotten) wood. There is a layer of old fake-wood flooring that is not strong enough to hold new flooring (spongy)
I have removed most of the rotten wood flooring (which is dry, not wet) and the plywood below it where needed. There is a good sized area that needs to be fixed. Maybe 2 square feet, in an irregular shape. Below the rotten wood and rotten plywood is more solid wood - there are no joists visible. I guess I didn't get deep enough to hit those yet. This is an older house and I'm not sure how many layers of flooring there are, and it's difficult to get below that part of the house to check on things (it's a muddy and very low crawl space).
Anyway, since the repair is quite deep and irregular (inch and a half deep in some places) my thought for fixing this are as follows. Would be interested in any opinions on this course of action.
1) Remove any remaining rotten wood
2) Apply wood hardener, wait until dry
3) Fill and patch with floor leveling compound
4) Apply my new stick-on tiles
If this sounds OK, what is a good type of floor leveling compound to use?
Thanks for any input.
