I am getting ready to pull up the old carpet and install laminate click flooring. Can I reuse the under carpet padding or is it too spongy? Thanks.
Can I use carpet pad for laminate flooring?
No you cannot use carpet padding under laminate flooring. It is far to spongy and will allow so much give that the laminate planks will break off the tongues.
Plus make sure you remove ALL the carpet padding staples, they are laminate killers as well.
Laminate is easy to install, stands up to all kinds of wear and tear, and is relatively inexpensive. It doesn't require removal of any type of existing flooring except carpet, and in most cases, no special prep work is needed to install a floating laminate floor.Comment
