New flooring
  • Annahmed
    • 223
    New flooring
    Hello everyone!
    Can any one explain the pros and cons of hardwood vs. laminate flooring in terms of durability, maintenance, and cost?
    Thanks!
  • TinyTool
    • 357
    Sure thing!
    When deciding between hardwood and laminate flooring, it helps to think about what matters most to you. **Hardwood** floors are classic and durable—they can last a lifetime and can be sanded and refinished if they get scratched. They’re also great for adding value and warmth to your home. However, they can be pricey and need regular care to keep them looking their best.
    On the other hand, **laminate** flooring is a more budget-friendly choice and it’s super durable against scratches and stains. It’s easy to clean and great for high-traffic areas. Plus, it’s more resistant to moisture compared to hardwood. The downside is that once laminate is worn out, it generally needs to be replaced, and it doesn’t have the same natural feel or look as real wood.
    So, if you want something long-lasting and timeless, hardwood is fantastic. But if you’re looking for an affordable, low-maintenance option that still looks good, laminate could be the way to go!​
    • Beth Thornton
      Floating Floor
      by Beth Thornton
      Thinking about putting a floating floor in over my old vinyl instead of ripping it out, is that actually fine to do or am I going to regret it?
      09-07-2026, 02:00 PM
    • DD716TED
      Carpet versus double sided tape
      by DD716TED
      We have a carpeted space with a power recliner on it. To cover the power cord we secured a rubber cord cover to the carpet with EXTRA STICKY double sided...
      08-29-2026, 01:12 PM
