The caulking or sealant that caulks the seam between the fiberglass tub side / vinyl floor is cracking and needs replacement. One hardware store says to use a white pure silicone sealant while another store says to use something else that isn't as glossy as the silicone (forgot product name). What should I use to recaulk this seam/joint??
Vinyl Floor - Fiberglass Tub joint / seam???
Hello DD716TED! I agree with Patriotic and pushkins, silicone is the way to go. There are some silicone caulks that are permanently waterproof and flexible available at your local home improvement store. Silicone will not shrink, crack, or crumble over time and adheres to a wide variety of surfaces. Some now contain mold and mildew protection - great for use in the bathroom where you will be using the product.
Be sure to check the area where cracking is currently occurring for mold, mildew, and other debris. Take care of that first, then clean and prep the area, finally use the silicone. Best wishes and keep us posted on your progress!Comment
