I have a honeywell R8182D controller. Last week the reset kicked out and I had to reset it (press it) and the burner fired up. I happened a couple more times but each time I pressed the reset and it fired up. This moring it would not start. I pulled the gun and it looks like it's getting fuel, I also bled the line and I didn't have any air. The blower runs so apparently I'm not getting spark. I think the blower and transformer power come off the same termanals on the controller B1-C2 so if the blower is working it must be the transformer.
Does anyone know what the voltage should be between B1 and C2.
Also is there an easy way to test the transformer (I'm trying not to get belted with high voltage).
