Here is my issue:
I had the pressure relief valve replaced due to it leaking by.
New valve has same problem but I'm thinking the valve is functioning properly but the tank is actually pressurizing to 31psi causing the valve to open (Rated for 30 psi).
I have found information about the temperature high and low cutoffs for the burner but there is nothing in the manual indicating normal operating psi levels.
So my questions are as follows:
1) What is the normal psi range for the tank.
2) Is there a way to lower the psi in the tank(lowering temperature)
3) is there a possibility that one of the control components is going bad?
Furnace heats my house and generates hot water just fine and I'm not looking to replace it anytime soon I just want the pressure relief to stop lifting.
