I've done some research on the internet and think I know what the problem is. The blinking red light blinks four times indicating the "thermal protection device open".
The unit had been working fine this whole season. We stopped using it a few weeks ago when the weather warmed up a bit. The past few days it got a bit cold here and we tried running it. It is now just blowing cold air. I found the red light blinking as stated above. Normally when it is working properly, the burner kicks on and then the blower. Now the blower starts up right away and no heating up of the igniter at all.
This unit is a little over 18 years old and has worked flawlessly since it was new.
I'm fairly handy and feel that I could probably replace what needs to be replaced, but I'm wondering if it would be prudent to have someone come and look at it since there is a possibility that the thermal protection tripped for a reason, not just because it was old or worn out.
I would appreciate any tips, suggestions or help you all may have. Thanks in advance for your help.
