Lightning stuck my Trane split system TWE 031E13FB1 I verified control voltage in AC and fan mode while installed and suspect the fan is bad.
How do I test this 1/2 HP MOT9229 motor, I was thinking I could apply 220V to the 3 connectors and but no hum and motor does not turn when rotation started manually.
I see there are many compatable motor models available but not very many of them for less than $300
I had to replace both control boards, the condensor unit was forcing heating strips on and the compressor cca was forcing defrost., pulled vacuum and recharged, I have cold lines to air handler unit.
Thanks for any suggestions
