Outside AC unit not turning on !
Paul here, I just found the wiring diagram on your board Take Yellow T1 off the board, Take Red T2 wire off the board Tape these two wires together and it should work. Leave T3 wires on the board. PaulComment
Thank you. I will bypass this thing next time it turns off. Been working fine today go figure So basically it's hooking the small white wire(from the Tstat) to the side post on the contractor ?
Is the diagram the one on the 621586 Anti Short-Cycle Timer ? its the replacement for the I have but think it's the same.
Ok so I was right, I was gona connect the red and yellow just wanted to make sure, I hate electrical stuff. I got a big zap last night when I was looking to were all the wires go and try to learn how they work. Think my ring caught a the cap post,,,,,,,,,,,, my hand was still tingling 30 minutes later LOL
I sure appreciate all the help ! We just had the AC guy out before this happened so couldn't afford him to come out again.Comment
wiring should be the same on both boards. PaulThank you. I will bypass this thing next time it turns off. Been working fine today go figure So basically it's hooking the small white wire(from the Tstat) to the side post on the contractor ?
