AC cooling fan motor
  • Guyvh1
    • Aug 2011
    Hello, my AC cooling fan motor stop working un less i give it a push. The local supplier only had a bi-directional single Phase HP 1/3-1/8, volts 208-230.
    My question, is it possible to wire this unit for single direction without using a switch?
  • paul52446m
    • Nov 2009
    • 690
    If you look at the motor it will have a diagram to tell you how to make it go the direction you want. Make sure you buy the right capasator for it. Paul
