AC cooling fan motor
  • Guyvh1
    • Aug 2011
    Hello, my AC cooling fan motor stop working un less i give it a push. The local supplier only had a bi-directional single Phase HP 1/3-1/8, volts 208-230.
    My question, is it possible to wire this unit for single direction without using a switch?
  • paul52446m
    • Nov 2009
    • 690
    If you look at the motor it will have a diagram to tell you how to make it go the direction you want. Make sure you buy the right capasator for it. Paul
    • 911Restoration
      Fireplace Woes
      by 911Restoration
      09-22-2026, 03:14 PM
      Laser 730 over firing
      by hawkins111
      Has anyone had an occurrence of a Laser 730 or 731 over firing?
      The top of the heat chamber and the heat exchanger glow red on high when this occurs....
      11-12-2024, 10:29 AM
