View Post
I did locate the room stat wires from upstairs down to the furnace room.
They are going directly into the old systems' electric hot water valve.
From there, it the valve's power line and stat line goes to another zone box.
(I'll post pics of it when I get home later.)
Then from that zone box goes to the 2 red circulator pumps on the old system.
It's NOT going to the Thermostat panel box I pictured a couple of posts ago.
Apparently, that box is for the old,now defunct Cantherm 520 Ground Source system using the universal relay for the compressor pump.
So, what I think I need to do is remove the red pump wires over to the blue water heaters' circulator pump and the upstairs room stat will be in business.
I will have to remove the present blue pump (black and common trip) wires over to this old room stat zone wires.
This way the room stat will control the pump as the water heaters' temp is already controlled by the panel box's stat sensor bulb.
