I have a Bryant Furnace Model # 310AAV036070AAJA. It is not heating or cooling. The thermostat is showing a little flame icon. We have checked to make sure the burner is ignited and the LED light is on but occasionally flashes. I have no idea what it could be and my house is freezing!! I cannot really afford to call a repair man. Anything will help! Thank you!
Bryant Furnace Not Heating
Tags: None
Have you tried turning the stat down for 5 min to recycle it?I have a Bryant Furnace Model # 310AAV036070AAJA. It is not heating or cooling. The thermostat is showing a little flame icon. We have checked to make sure the burner is ignited and the LED light is on but occasionally flashes. I have no idea what it could be and my house is freezing!! I cannot really afford to call a repair man. Anything will help! Thank you!
On your electronic board, there is a plug in fuse like you see in a car, check that out, it is a small amp fuse , do not use a larger one. Does anything happen at all when you turned the stat?. How old is your furnace? Paul
Channel: Toyo Heaters
