I have a Casablanca floor model 19N8F fan, 110VAC. It has worked well for several years (and is out of warranty) until recently. It has a off-3 speed switch. Off works. Low speed works. Medium speed stays the same as low speed. High speed works. So it is missing the medium speed. I would like to fix it myself (I am a mechanical engineer and routinely do home wiring) - what should I look for when I open it up? Is a loose wire likely? What part am I likely to need? I am checking but I think Casablanca would just want to replace the whole thing ($$$) rather than fix it ($$).
Thanks! Bill_H
Thanks! Bill_H
